주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Enabot EBO SE Battery Replacement
필요한 것
    1. Enabot EBO SE Battery Replacement, Wheel Assembly: 1 단계, 이미지 1개 중 1개
      • Gently turn the robot upside down.
      • Place the robot on a stable surface to prevent it from rolling or falling.
      댓글 쓰기
    2. Enabot EBO SE Battery Replacement: 2 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement: 2 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
      • A tool should have been provided in the box for this purpose.
      댓글 쓰기
    3. Enabot EBO SE Battery Replacement: 3 단계, 이미지 2개 중 1개 Enabot EBO SE Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Pull the wheel assembly towards you so it comes straight off without resistance.
      • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
      댓글 쓰기
    1. Enabot EBO SE Battery Replacement, Lower Housing: 4 단계, 이미지 2개 중 1개 Enabot EBO SE Battery Replacement, Lower Housing: 4 단계, 이미지 2개 중 2개
      • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
      댓글 쓰기
    2. Enabot EBO SE Battery Replacement: 5 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement: 5 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
      • Keep the Micro SD Card in a safe spot for later.
      댓글 쓰기
    3. Enabot EBO SE Battery Replacement: 6 단계, 이미지 2개 중 1개 Enabot EBO SE Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Place the iFixit opening tool inside the Micro SD slot.
      • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
      댓글 쓰기
    4. Enabot EBO SE Battery Replacement: 7 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement: 7 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
      • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
      댓글 쓰기
    5. Enabot EBO SE Battery Replacement: 8 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement: 8 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement: 8 단계, 이미지 3개 중 3개
      • There are two black and red wire connectors attached to the upper and lower housing.
      • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
      댓글 쓰기
    1. Enabot EBO SE Battery Replacement, Battery: 9 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement, Battery: 9 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement, Battery: 9 단계, 이미지 3개 중 3개
      • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
      • Flip the tab up and pull the ribbon cable out.
      • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
      댓글 쓰기
    2. Enabot EBO SE Battery Replacement: 10 단계, 이미지 3개 중 1개 Enabot EBO SE Battery Replacement: 10 단계, 이미지 3개 중 2개 Enabot EBO SE Battery Replacement: 10 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
      댓글 쓰기
    3. Enabot EBO SE Battery Replacement: 11 단계, 이미지 2개 중 1개 Enabot EBO SE Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Pull the battery casing upwards from the lower half of the assembly to remove it.
      댓글 쓰기
    4. Enabot EBO SE Battery Replacement: 12 단계, 이미지 2개 중 1개 Enabot EBO SE Battery Replacement: 12 단계, 이미지 2개 중 2개
      • Carefully remove the battery from the casing in order to replace.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevin H.
회원 가입일: 02/15/24
716 평판
안내서 5개를 작성함
8가이드 댓글
Una guía fantástica, pero no puedo seguirla porque no encuentro el recambio de la batería ¿Se puede usar una genérica? ¿Alguna referencia que me ayude a encontrar el recambio?
Rubén Belmonte - 답글 공유
tengo la misma duda, entendí perfecto el tutorial, que tipo de batería lleva?
Marina Daniela Regali - 답글 공유
What type of battery?
Commissioner Gordon - 답글 공유
18650 battery with ph2.0/2p connector
Camilo Jiménez - 답글 공유
Do you know what's the original battery capacity in mah?
wcy pierre - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 42
지난 30일: 221
전체 시간: 4,567
