주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Replace the encoder strip.
부품
지정된 부품이 없습니다.
  1. Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. Press down on the two plastic hinges to remove the upper portion of printer. Press down on the two plastic hinges to remove the upper portion of printer.
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
    • To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
  5. Rotate the printer so the paper tray is facing towards you. Gently lift the scanner tray up and away from the printer.
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward toward to release the tabs from the printer.
  6. Returning to the back of the printer, remove the scanner from the back hinges.
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  7. Gently grasp and unplug the two white ribbon cables from the printer body.
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  10. Locate the panel labeled with a HP support link sticker. Release the tab by the support link sticker.
    • Locate the panel labeled with a HP support link sticker.
    • Release the tab by the support link sticker.
    • Remove the black screw below the tab.
  11. Remove the two black screws closest to the printer tray.
    • Remove the two black screws closest to the printer tray.
  12. Unhook the encoder strip from its small silver hooks and remove it from the printer.
    • Unhook the encoder strip from its small silver hooks and remove it from the printer.
    • To replace, feed the new encoder strip through the silver hooks.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jeremy Mahrt
회원 가입일: 2011년 05월 08일
283 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011 회원
CPSU-MANESS-S11S12G31
5 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 40
30일 전: 189
전체 시간: 23,433
