이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Press down on the two plastic hinges to remove the upper portion of printer.
Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
Rotate the printer so the paper tray is facing towards you.
Gently lift the scanner tray up and away from the printer.
Press the gray plastic tabs inward to release the tabs from the printer.
Returning to the back of the printer, remove the scanner from the back hinges.
Gently grasp and unplug the two white ribbon cables from the printer body.
Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Locate the panel labeled with a HP support link sticker.
Release the tab by the support link sticker.
Remove the black screw below the tab.
Unhook the encoder strip from its small silver hooks and remove it from the printer.
To replace, feed the new encoder strip through the silver hooks.
다른 4명이 해당 안내서를 완성하였습니다.
