소개
The batteries included in the packs are prone to failure and leaking. This guide will show you how to replace the batteries with better quality rechargeables.
필요한 것
Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Mike Propp - 답글
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
martinlu82 - 답글
