소개
Disassemble the engine brake (allows the operator to slow or stop the engine) in order to replace the return spring, bolts, brackets, or cable.
부품
부품은 필요하지 않습니다.
  1. Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Beware! The spring is very strong and injury could result if proper care is not exercised.
    • Remove the two bolts using a 7/16 socket.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Push the metal tab closest to the black wire down
    • Push the metal tab closest to the black wire down
    • While pushing the tab down, pull the black wire out of the clip.
    • Disassembly is complete!
결론
Jacob Micallef
회원 가입일: 2017년 03월 06일
782 평판
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 32
