주요 콘텐츠로 건너뛰기
Entry Door Weatherstripping Replacement
필요한 것
  1. Entry Door Weatherstripping Replacement, Weatherstripping: 1 단계, 이미지 1/2 Entry Door Weatherstripping Replacement, Weatherstripping: 1 단계, 이미지 2/2
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: 2 단계, 이미지 1/3 Entry Door Weatherstripping Replacement: 2 단계, 이미지 2/3 Entry Door Weatherstripping Replacement: 2 단계, 이미지 3/3
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: 3 단계, 이미지 1/1
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: 4 단계, 이미지 1/2 Entry Door Weatherstripping Replacement: 4 단계, 이미지 2/2
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: 5 단계, 이미지 1/2 Entry Door Weatherstripping Replacement: 5 단계, 이미지 2/2
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: 6 단계, 이미지 1/3 Entry Door Weatherstripping Replacement: 6 단계, 이미지 2/3 Entry Door Weatherstripping Replacement: 6 단계, 이미지 3/3
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: 7 단계, 이미지 1/1
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: 8 단계, 이미지 1/2 Entry Door Weatherstripping Replacement: 8 단계, 이미지 2/2
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
결론
Agilakumaran Shanmugalingam
회원 가입일: 05/10/21
157 평판
안내서 1개 작성함
York University, Team S1-G26, O'Regan Summer 2021 York University, Team S1-G26, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G26
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 42
30일 전: 189
전체 시간: 5,129
