주요 콘텐츠로 건너뛰기
Entry Door Weatherstripping Replacement
필요한 것
  1. Entry Door Weatherstripping Replacement, Weatherstripping: 1 단계, 이미지 2개 중 1개 Entry Door Weatherstripping Replacement, Weatherstripping: 1 단계, 이미지 2개 중 2개
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: 2 단계, 이미지 3개 중 1개 Entry Door Weatherstripping Replacement: 2 단계, 이미지 3개 중 2개 Entry Door Weatherstripping Replacement: 2 단계, 이미지 3개 중 3개
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: 3 단계, 이미지 1개 중 1개
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: 4 단계, 이미지 2개 중 1개 Entry Door Weatherstripping Replacement: 4 단계, 이미지 2개 중 2개
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: 5 단계, 이미지 2개 중 1개 Entry Door Weatherstripping Replacement: 5 단계, 이미지 2개 중 2개
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: 6 단계, 이미지 3개 중 1개 Entry Door Weatherstripping Replacement: 6 단계, 이미지 3개 중 2개 Entry Door Weatherstripping Replacement: 6 단계, 이미지 3개 중 3개
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: 7 단계, 이미지 1개 중 1개
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: 8 단계, 이미지 2개 중 1개 Entry Door Weatherstripping Replacement: 8 단계, 이미지 2개 중 2개
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
결론
작성자
1다른 기여자 명과 함께
Agilakumaran Shanmugalingam
회원 가입일: 05/10/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 77
지난 30일: 244
전체 시간: 8,359
