주요 콘텐츠로 건너뛰기
Envizen V100M Speakers Replacement
필요한 것
  1. Envizen V100M Speakers Replacement, Back Cover: 1 단계, 이미지 1/2 Envizen V100M Speakers Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: 2 단계, 이미지 1/3 Envizen V100M Speakers Replacement: 2 단계, 이미지 2/3 Envizen V100M Speakers Replacement: 2 단계, 이미지 3/3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: 3 단계, 이미지 1/1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: 4 단계, 이미지 1/1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: 5 단계, 이미지 1/1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
결론
nbach
회원 가입일: 03/23/15
663 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-2, Duarte Spring 2015 UMass Dartmouth, Team 3-2, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 97
