주요 콘텐츠로 건너뛰기
Epiphone ES-335 PRO Pickguard Replacement
필요한 것
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: 1 단계, 이미지 1/1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: 2 단계, 이미지 1/2 Epiphone ES-335 PRO Pickguard Replacement: 2 단계, 이미지 2/2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
결론
Michaih Ley Bayani
회원 가입일: 03/28/18
515 평판
안내서 4개 작성하였습니다
University of Memphis, Team S1-G4, Kim Spring 2018 University of Memphis, Team S1-G4, Kim Spring 2018 회원
UM-KIM-S18S1G4
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 93
전체 시간: 4,586
