주요 콘텐츠로 건너뛰기
Epiphone Les Paul Special Input Jack Replacement
필요한 것
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: 1 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: 2 단계, 이미지 1/1
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: 3 단계, 이미지 1/2 Epiphone Les Paul Special Input Jack Replacement: 3 단계, 이미지 2/2
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: 4 단계, 이미지 1/1
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: 5 단계, 이미지 1/1
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: 6 단계, 이미지 1/2 Epiphone Les Paul Special Input Jack Replacement: 6 단계, 이미지 2/2
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: 7 단계, 이미지 1/2 Epiphone Les Paul Special Input Jack Replacement: 7 단계, 이미지 2/2
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: 8 단계, 이미지 1/1
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: 9 단계, 이미지 1/1
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
결론
To get everything back into its original place, follow steps 1-7 in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Peyton Deane
회원 가입일: 09/15/20
225 평판
안내서 1개 작성함
University of Memphis, Team S1-G6, Bishop Fall 2020 University of Memphis, Team S1-G6, Bishop Fall 2020 회원
UM-BISHOP-F20S1G6
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 82
전체 시간: 4,115
