주요 콘텐츠로 건너뛰기
Epomaker SK64S Keyboard Switches Replacement
필요한 것
  1. Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 1 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 1 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 1 단계, 이미지 3/3
    • Do not disassemble keyboard if it is connected to a power source.
    • Unplug the power cable.
  2. Epomaker SK64S Keyboard Switches Replacement: 2 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 2 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 2 단계, 이미지 3/3
    • Align the keycap puller with the keycap.
    • Pull the keycap straight out.
    • Remove all of the keys.
  3. Epomaker SK64S Keyboard Switches Replacement: 3 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 3 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 3 단계, 이미지 3/3
    • Fill the plastic container with water.
    • Add two drops of dish soap.
    • Put in the keycaps.
    • Let the keycaps soak for 30 minutes.
  4. Epomaker SK64S Keyboard Switches Replacement: 4 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 4 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 4 단계, 이미지 3/3
    • Take the keycaps out.
    • Place them on a paper towel.
    • Let the keycaps dry out.
  5. Epomaker SK64S Keyboard Switches Replacement: 5 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 5 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 5 단계, 이미지 3/3
    • Use an alcohol wipe to soak the cotton swab.
    • Clean the board by running the cotton swab along the board.
  6. Epomaker SK64S Keyboard Switches Replacement: 6 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 6 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 6 단계, 이미지 3/3
    • Align the switch puller with the faulty switch.
    • Pull the switch straight out.
  7. Epomaker SK64S Keyboard Switches Replacement: 7 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 7 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 7 단계, 이미지 3/3
    • Align the new key switch.
    • Push the key switch straight down.
  8. Epomaker SK64S Keyboard Switches Replacement: 8 단계, 이미지 1/3 Epomaker SK64S Keyboard Switches Replacement: 8 단계, 이미지 2/3 Epomaker SK64S Keyboard Switches Replacement: 8 단계, 이미지 3/3
    • Align the keycap.
    • Push the keycap straight down.
    • Replace all the keycaps.
결론
Type away!
다른 2명이 해당 안내서를 완성하였습니다.
Muhammad Talha
회원 가입일: 09/29/20
211 평판
안내서 1개 작성함
University of North Texas, Team S2-G4, Raign Fall 2020 University of North Texas, Team S2-G4, Raign Fall 2020 회원
UNT-RAIGN-F20S2G4
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 804
