주요 콘텐츠로 건너뛰기
Epomaker Shadow-X Switch Plate Re-alignment
필요한 것
  1. Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: 1 단계, 이미지 3개 중 1개 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: 1 단계, 이미지 3개 중 2개 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: 1 단계, 이미지 3개 중 3개
    • Power off the keyboard and disconnect any USB cable.
    • Place the keyboard on a clean, static-free workspace.
  2. Epomaker Shadow-X Switch Plate Re-alignment: 2 단계, 이미지 1개 중 1개
    • Use a keycap puller/spudger to remove all keycaps on the keyboard.
  3. Epomaker Shadow-X Switch Plate Re-alignment: 3 단계, 이미지 1개 중 1개
    • Remove the screws on the back of the keyboard with a hex screwdriver.
    • Carefully pry open the case using a plastic opening tool or spudger, and separate the top and bottom halves.
  4. Epomaker Shadow-X Switch Plate Re-alignment: 4 단계, 이미지 1개 중 1개
    • Locate the switch plate, which sits between the key switches and the PCB.
    • If the switch plate is misaligned, carefully adjust it so that it sits flush and aligns with all switch positions.
    • Ensure that each switch slot in the plate lines up with the PCB holes below it.
  5. Epomaker Shadow-X Switch Plate Re-alignment: 5 단계, 이미지 1개 중 1개
    • If the plate has screws or clips, check that each one is correctly fastened to prevent future misalignment.
    • Gently press on different sections of the plate to verify that it’s stable and correctly positioned over the PCB.
  6. Epomaker Shadow-X Switch Plate Re-alignment: 6 단계, 이미지 3개 중 1개 Epomaker Shadow-X Switch Plate Re-alignment: 6 단계, 이미지 3개 중 2개 Epomaker Shadow-X Switch Plate Re-alignment: 6 단계, 이미지 3개 중 3개
    • Reinsert each switch, ensuring that they align with both the switch plate and the PCB.
    • Snap the top and bottom halves of the case back together. Replace and tighten all screws.
    • Reinstall all keycaps and check that they are aligned and consistent in height.
결론
You have successfully realigned the switch plate on your Epomaker Shadow-X keyboard! This adjustment improves switch stability and typing consistency. Check each key to confirm the alignment, and enjoy smoother, more consistent typing.
작성자
2다른 기여자 명과 함께
Beck Spitler
회원 가입일: 08/28/24
611 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 177
