주요 콘텐츠로 건너뛰기
Epomaker Shadow-X Switch Replacement
필요한 것
  1. Epomaker Shadow-X Switch Replacement, Switch: 1 단계, 이미지 2개 중 1개 Epomaker Shadow-X Switch Replacement, Switch: 1 단계, 이미지 2개 중 2개
    • Unplug or disconnect the keyboard from the PC.
    • Turn off and unplug the keyboard if connected via USB-C.
    • If using Bluetooth, disconnect it from all paired devices.
  2. Epomaker Shadow-X Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Use a keycap puller to remove each keycap over the switches you plan to replace.
    • Gently pull upward to avoid damaging the keycap or switch stem.
  3. Epomaker Shadow-X Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Use a switch puller to press the clips on each side of the switch.
    • Gently pull the switch straight up to remove it from the socket.
  4. Epomaker Shadow-X Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Align the pins of the new switch with the socket or PCB holes. Carefully press the switch into place until it clicks or fits snugly into the PCB.
결론
You’ve completed the switch replacement on your Epomaker Shadow-X keyboard! With new switches installed, your keyboard should offer an improved typing experience. Test each key to ensure they’re responsive, and enjoy the renewed feel of your keyboard.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chase Fulsom
회원 가입일: 08/28/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 13
전체 시간: 182
