소개
The lamp is the most important part of the Epson Brightlink 450Wi; it allows the image to be projected onto the screen by shining a light through the LCD system. Without a working lamp, your device is essentially useless; so it is very important to make sure your lamp is properly working.
For such an important part, it is luckily a replacement that just about anyone can perform. In the event your lamp isn't working right or when in need of replacement, follow this guide.
필요한 것
Rotate Projector so you are looking at the right corner, next to the white EPSON logo.
On the right side, begin to unscrew the 11 mm screw.
