주요 콘텐츠로 건너뛰기
Epson PPC650 Camera Case Replacement
필요한 것
  1. Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 1/3 Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 2/3 Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 3/3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Camera Case Replacement: 2 단계, 이미지 1/1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Camera Case Replacement: 3 단계, 이미지 1/2 Epson PPC650 Camera Case Replacement: 3 단계, 이미지 2/2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Camera Case Replacement: 4 단계, 이미지 1/1
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Camera Case Replacement: 5 단계, 이미지 1/3 Epson PPC650 Camera Case Replacement: 5 단계, 이미지 2/3 Epson PPC650 Camera Case Replacement: 5 단계, 이미지 3/3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
결론
Brittany
회원 가입일: 02/12/13
101 평판
안내서 1개 작성함
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 14
전체 시간: 158
