주요 콘텐츠로 건너뛰기
Epson PPC650 Screen Replacement
필요한 것
  1. Epson PPC650 Screen Replacement, Case: 1 단계, 이미지 3개 중 1개 Epson PPC650 Screen Replacement, Case: 1 단계, 이미지 3개 중 2개 Epson PPC650 Screen Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
  2. Epson PPC650 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two screws on the rounded side of the camera.
  3. Epson PPC650 Screen Replacement: 3 단계, 이미지 2개 중 1개 Epson PPC650 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
  4. Epson PPC650 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four screws from the bottom of the camera.
  5. Epson PPC650 Screen Replacement: 5 단계, 이미지 3개 중 1개 Epson PPC650 Screen Replacement: 5 단계, 이미지 3개 중 2개 Epson PPC650 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
  6. Epson PPC650 Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Epson PPC650 Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Epson PPC650 Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Remove the copper sheet from the front and back paneling.
    • Use the spudger to unsolder the copper paneling.
    • Use the spudger to separate the back circuit board from the camera.
  7. Epson PPC650 Screen Replacement: 7 단계, 이미지 2개 중 1개 Epson PPC650 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
    • Exert minimal force to pull the screen loose from the camera.
    • Remove the pink and white wiring from the internal paneling. These wires are soldered in.
    • Remove the orange data hookup cable that feeds into the back circuit board.
    • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
    • Insert data hookup into the back of the camera and into the new screen.
    • Re-solder the new pink and white wire onto the internal circuit board.
결론
작성자
7다른 기여자 명과 함께
Anne
회원 가입일: 02/12/13
101 평판
안내서 1개를 작성함
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 7
전체 시간: 524
