주요 콘텐츠로 건너뛰기
Epson PowerLite 77c Button Panel Replacement
필요한 것
  1. Epson PowerLite 77c Button Panel Replacement, Top Panel: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Button Panel Replacement: 2 단계, 이미지 2개 중 1개 Epson PowerLite 77c Button Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Button Panel Replacement, Button Panel: 3 단계, 이미지 1개 중 1개
    • On the underside of the top panel, use a Phillips #0 to remove the four screws securing the button panel.
  4. Epson PowerLite 77c Button Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the button panel.
결론
작성자
2다른 기여자 명과 함께
Julia Costantino
회원 가입일: 02/08/22
234 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 162
