주요 콘텐츠로 건너뛰기
Epson PowerLite 77c Top Panel Replacement
필요한 것
  1. Epson PowerLite 77c Top Panel Replacement, Top Panel: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Top Panel Replacement: 2 단계, 이미지 2개 중 1개 Epson PowerLite 77c Top Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
결론
작성자
2다른 기여자 명과 함께
Connor Bassolino
회원 가입일: 03/29/22
17,370 평판
안내서 74개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,644개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 93
