주요 콘텐츠로 건너뛰기
Epson PowerLite 822 Plus Projector Lens Replacement
필요한 것
  1. Epson PowerLite 822 Plus Projector Lens Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite 822 Plus Projector Lens Replacement: 2 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 2 단계, 이미지 2개 중 2개
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite 822 Plus Projector Lens Replacement: 3 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 3 단계, 이미지 2개 중 2개
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite 822 Plus Projector Lens Replacement: 4 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite 822 Plus Projector Lens Replacement: 5 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite 822 Plus Projector Lens Replacement: 6 단계, 이미지 3개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 6 단계, 이미지 3개 중 2개 Epson PowerLite 822 Plus Projector Lens Replacement: 6 단계, 이미지 3개 중 3개
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite 822 Plus Projector Lens Replacement: 7 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 7 단계, 이미지 2개 중 2개
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite 822 Plus Projector Lens Replacement: 8 단계, 이미지 3개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 8 단계, 이미지 3개 중 2개 Epson PowerLite 822 Plus Projector Lens Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite 822 Plus Projector Lens Replacement: 9 단계, 이미지 1개 중 1개
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 10 단계, 이미지 3개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 10 단계, 이미지 3개 중 2개 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 10 단계, 이미지 3개 중 3개
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that hold together the fan bracket.
  11. Epson PowerLite 822 Plus Projector Lens Replacement: 11 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 11 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that secure the projector.
  12. Epson PowerLite 822 Plus Projector Lens Replacement: 12 단계, 이미지 2개 중 1개 Epson PowerLite 822 Plus Projector Lens Replacement: 12 단계, 이미지 2개 중 2개
    • Pull out the loose projector and it is ready to be replaced.
결론
작성자
2다른 기여자 명과 함께
Emma Richey
회원 가입일: 03/21/22
915 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 7
전체 시간: 166
