주요 콘텐츠로 건너뛰기
Epson PowerLite 83+ Motherboard Replacement
필요한 것
  1. Epson PowerLite 83+ Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
결론
작성자
3다른 기여자 명과 함께
Lucas Bell
회원 가입일: 02/22/22
229 평판
안내서 2개를 작성함
Clemson, Team 2-4, Hunter Spring 2022 Clemson, Team 2-4, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 414
