주요 콘텐츠로 건너뛰기
Epson PowerLite 83+ Power Supply Replacement
필요한 것
  1. Epson PowerLite 83+ Power Supply Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Power Supply Replacement: 2 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 2 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Power Supply Replacement: 3 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Power Supply Replacement: 4 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 4 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Power Supply Replacement: 5 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 5 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement: 5 단계, 이미지 3개 중 3개
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Power Supply Replacement: 6 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 6 단계, 이미지 2개 중 2개
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Power Supply Replacement: 7 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 7 단계, 이미지 2개 중 2개
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
  8. Epson PowerLite 83+ Power Supply Replacement, Projector Lens: 8 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement, Projector Lens: 8 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement, Projector Lens: 8 단계, 이미지 3개 중 3개
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
  9. Epson PowerLite 83+ Power Supply Replacement: 9 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 9 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
  10. Epson PowerLite 83+ Power Supply Replacement: 10 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 10 단계, 이미지 2개 중 2개
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
  11. Epson PowerLite 83+ Power Supply Replacement, Power Supply: 11 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement, Power Supply: 11 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement, Power Supply: 11 단계, 이미지 3개 중 3개
    • Remove the sensor using a spudger and lifting it from the bottom.
  12. Epson PowerLite 83+ Power Supply Replacement: 12 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the lamp's power plug by rocking towards the fan's vent and then pulling up.
  13. Epson PowerLite 83+ Power Supply Replacement: 13 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the three 6 mm Phillips #2 screws securing the power supply.
    • The screw located by the power supply's fan is near a magnetic field. Reinserting this screw can be difficult.
  14. Epson PowerLite 83+ Power Supply Replacement: 14 단계, 이미지 3개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 14 단계, 이미지 3개 중 2개 Epson PowerLite 83+ Power Supply Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the two 6 mm Phillips #2 screws securing the wire guide.
    • Remove the wires by gently lifting up the wire guide.
  15. Epson PowerLite 83+ Power Supply Replacement: 15 단계, 이미지 2개 중 1개 Epson PowerLite 83+ Power Supply Replacement: 15 단계, 이미지 2개 중 2개
    • Using your fingers, firmly press in the sides of the power plug while lifting up.
    • Remove the power supply.
결론
작성자
3다른 기여자 명과 함께
Blake Davis
회원 가입일: 02/22/22
181 평판
안내서 1개를 작성함
Clemson, Team 2-4, Hunter Spring 2022 Clemson, Team 2-4, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 225
