주요 콘텐츠로 건너뛰기
Epson PowerLite Home Cinema 1040 Lamp Replacement
필요한 것
  1. Epson PowerLite Home Cinema 1040 Lamp Replacement, Lamp: 1 단계, 이미지 1/1
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Lamp Replacement: 2 단계, 이미지 1/2 Epson PowerLite Home Cinema 1040 Lamp Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Lamp Replacement: 3 단계, 이미지 1/2 Epson PowerLite Home Cinema 1040 Lamp Replacement: 3 단계, 이미지 2/2
    • Slide the lamp cover off by sliding out, then up.
  4. Epson PowerLite Home Cinema 1040 Lamp Replacement: 4 단계, 이미지 1/2 Epson PowerLite Home Cinema 1040 Lamp Replacement: 4 단계, 이미지 2/2
    • Loosen the 7mm dark gray screws keeping the lamp in place.
    • The screws do not need to be removed. Simply loosening the screws will allow the lamp to slide out.
  5. Epson PowerLite Home Cinema 1040 Lamp Replacement: 5 단계, 이미지 1/1
    • Grip the lamp by its raised section, and carefully pull the lamp out of the projector to remove it.
    • The lamps contain mercury; consult state laws regarding disposal.
결론
Connor Didericksen
회원 가입일: 02/09/23
721 평판
안내서 6개 작성하였습니다
Utah Tech University, Team 1-6, McMurrin Spring 2023 Utah Tech University, Team 1-6, McMurrin Spring 2023 회원
UTAHTECH-MCMURRIN-S23S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 270
