주요 콘텐츠로 건너뛰기
Epson Powerlite Power Supply Replacement
필요한 것
  1. Epson Powerlite Power Supply Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson Powerlite Power Supply Replacement: 2 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 2 단계, 이미지 2개 중 2개
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson Powerlite Power Supply Replacement: 3 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 3 단계, 이미지 2개 중 2개
    • Use the spudger to disconnect it from the motherboard.
  4. Epson Powerlite Power Supply Replacement: 4 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 4 단계, 이미지 2개 중 2개
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson Powerlite Power Supply Replacement: 5 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson Powerlite Power Supply Replacement: 6 단계, 이미지 3개 중 1개 Epson Powerlite Power Supply Replacement: 6 단계, 이미지 3개 중 2개 Epson Powerlite Power Supply Replacement: 6 단계, 이미지 3개 중 3개
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson Powerlite Power Supply Replacement: 7 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 7 단계, 이미지 2개 중 2개
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson Powerlite Power Supply Replacement: 8 단계, 이미지 3개 중 1개 Epson Powerlite Power Supply Replacement: 8 단계, 이미지 3개 중 2개 Epson Powerlite Power Supply Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson Powerlite Power Supply Replacement: 9 단계, 이미지 1개 중 1개
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson Powerlite Power Supply Replacement, Projector Lens: 10 단계, 이미지 3개 중 1개 Epson Powerlite Power Supply Replacement, Projector Lens: 10 단계, 이미지 3개 중 2개 Epson Powerlite Power Supply Replacement, Projector Lens: 10 단계, 이미지 3개 중 3개
    • Unscrew the four 6mm screws that hold together the fan bracket.
  11. Epson Powerlite Power Supply Replacement: 11 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 11 단계, 이미지 2개 중 2개
    • Unscrew the four 6mm screws that secure the projector.
  12. Epson Powerlite Power Supply Replacement: 12 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement: 12 단계, 이미지 2개 중 2개
    • Pull out the loose projector.
  13. Epson Powerlite Power Supply Replacement, Power Supply: 13 단계, 이미지 2개 중 1개 Epson Powerlite Power Supply Replacement, Power Supply: 13 단계, 이미지 2개 중 2개
    • Remove the power plug attached to the bracket which kept the fan in place by rocking it back and forth and gently pull up when it is loose.
  14. Epson Powerlite Power Supply Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the rest of the bracket which helped keep the exhaust fan in place.
  15. Epson Powerlite Power Supply Replacement: 15 단계, 이미지 3개 중 1개 Epson Powerlite Power Supply Replacement: 15 단계, 이미지 3개 중 2개 Epson Powerlite Power Supply Replacement: 15 단계, 이미지 3개 중 3개
    • Use a Phillips #2 screwdriver to remove the two 6 mm screws that secure the wire guide.
  16. Epson Powerlite Power Supply Replacement: 16 단계, 이미지 3개 중 1개 Epson Powerlite Power Supply Replacement: 16 단계, 이미지 3개 중 2개 Epson Powerlite Power Supply Replacement: 16 단계, 이미지 3개 중 3개
    • Gently lift up the wire guide to remove the wires.
    • Use your fingers to firmly press on the sides of the power plug and lift it upward.
    • You will now be able to remove and replace the power supply.
결론
작성자
2다른 기여자 명과 함께
Emma Richey
회원 가입일: 03/21/22
915 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 1,001
