이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the control panel, the part of the printer with the buttons on it.
Push the control panel away from the outside of the printer, taking the panel out of the holes that hold it in place.
Repeat the above step for the other side of the control panel.
The front control panel is attached to the printer on both sides by a grey piece of plastic that runs on a track. Remove the control panel from the track by pushing it away from the track on both sides.
Flip the detached control panel over so that the buttons are facing down.
Remove the two 3mm Phillips #2 screws from the back of the control panel.
Split the control panel in half by gently pulling on both sides of the seam that runs through the control panel.
Separate the two pieces to reveal the green circuit board.
Remove the green circuit board by lifting it up gently with your hands.
Remove the buttons with the plastic opening tool by pressing the front panel down and lifting the buttons up.
다른 2명이 해당 안내서를 완성하였습니다.
