소개
The ink cartridges allow you to print in a variety of colors, or simply in black and white. If one of the ink cartridges is empty, then you will need to replace it.
  1. Open the top of the printer so that the inside of the printer is visible. Press the red button.
    • Open the top of the printer so that the inside of the printer is visible. Press the red button.
    • The ink cartridges should be visible.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Grab the top of the cartridge that you need to replace and press in on the tab at the top of the cartridge.
    • Grab the top of the cartridge that you need to replace and press in on the tab at the top of the cartridge.
    • Pull the cartridge up and out of the ink tray
결론
Close the cover and hit the red button one last time. It will now move to the park position and "CHARGE" the cartridges.
다른 5명이 해당 안내서를 완성하였습니다.
Danielle Purdy
회원 가입일: 2014년 04월 07일
294 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014 회원
CPSU-FORTE-S14S6G1
4 회원들
안내서 5개 작성하였습니다
I tried cartridge 124 and 125 in black only (and it says ink cartridge not recognized and won't print even if the black cartridges are full). But I left the color ones empty! Do ALL of the cartridges have to be full in order for the printer to work?? I only do black and white print jobs so it doesn't make sense for me to buy color ink. Thanks a lot!!
kathleenngomez - 답글
no idea why replacing these cartridges was so confusing to me - but this article REALLY helped, thank you!
hi - 답글
When I tried these instructions the very first thing I tried did not work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Doris Crowley - 답글
When I tried these instructions the very first thing I tried did no work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Doris Crowley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 89
전체 시간: 9,833
