주요 콘텐츠로 건너뛰기
Epson Stylus NX230 Motor Replacement
필요한 것
  1. Epson Stylus NX230 Motor Replacement, Motherboard: 1 단계, 이미지 1/1
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motor Replacement: 2 단계, 이미지 1/2 Epson Stylus NX230 Motor Replacement: 2 단계, 이미지 2/2
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motor Replacement: 3 단계, 이미지 1/1
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motor Replacement: 4 단계, 이미지 1/2 Epson Stylus NX230 Motor Replacement: 4 단계, 이미지 2/2
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motor Replacement: 5 단계, 이미지 1/2 Epson Stylus NX230 Motor Replacement: 5 단계, 이미지 2/2
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motor Replacement: 6 단계, 이미지 1/3 Epson Stylus NX230 Motor Replacement: 6 단계, 이미지 2/3 Epson Stylus NX230 Motor Replacement: 6 단계, 이미지 3/3
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motor Replacement: 7 단계, 이미지 1/1
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
  8. Epson Stylus NX230 Motor Replacement, Motor: 8 단계, 이미지 1/1
    • Remove the four 3mm Phillips #2 screws attaching the motor to the printer.
  9. Epson Stylus NX230 Motor Replacement: 9 단계, 이미지 1/1
    • Place the printer on it's side so that the motherboard's location is facing up.
    • Push the motor up and out of the hole that it is in.
    • The motor will slide out of the hole at the top after that.
결론
Kimberly Pugel
회원 가입일: 04/07/14
404 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014 회원
CPSU-FORTE-S14S6G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 948
