주요 콘텐츠로 건너뛰기
Epson Stylus NX240 Side Buttons Replacement
필요한 것
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 1 단계, 이미지 1/2 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 1 단계, 이미지 2/2
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: 2 단계, 이미지 1/1
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: 4 단계, 이미지 1/1
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: 5 단계, 이미지 1/1
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: 6 단계, 이미지 1/1
    • All parts should be separate now to clean or replace.
결론
Joshua Fabel
회원 가입일: 10/13/16
104 평판
안내서 1개 작성함
University of Maine, Team 2-4, Diaz Fall 2016 University of Maine, Team 2-4, Diaz Fall 2016 회원
UMAINE-DIAZ-F16S2G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 591
