주요 콘텐츠로 건너뛰기
Epson Stylus Photo 1400 Housing Replacement
필요한 것
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: 1 단계, 이미지 1/1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: 2 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 2 단계, 이미지 2/2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: 3 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: 4 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 4 단계, 이미지 2/2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: 5 단계, 이미지 1/3 Epson Stylus Photo 1400 Housing Replacement: 5 단계, 이미지 2/3 Epson Stylus Photo 1400 Housing Replacement: 5 단계, 이미지 3/3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: 6 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 6 단계, 이미지 2/2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: 7 단계, 이미지 1/3 Epson Stylus Photo 1400 Housing Replacement: 7 단계, 이미지 2/3 Epson Stylus Photo 1400 Housing Replacement: 7 단계, 이미지 3/3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: 8 단계, 이미지 1/3 Epson Stylus Photo 1400 Housing Replacement: 8 단계, 이미지 2/3 Epson Stylus Photo 1400 Housing Replacement: 8 단계, 이미지 3/3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: 9 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 9 단계, 이미지 2/2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: 10 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 10 단계, 이미지 2/2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: 11 단계, 이미지 1/3 Epson Stylus Photo 1400 Housing Replacement: 11 단계, 이미지 2/3 Epson Stylus Photo 1400 Housing Replacement: 11 단계, 이미지 3/3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: 12 단계, 이미지 1/2 Epson Stylus Photo 1400 Housing Replacement: 12 단계, 이미지 2/2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Larry Huang
회원 가입일: 10/12/11
1,004 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 회원
CPSU-REGAN-F11S17G11
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 48
전체 시간: 7,582
