주요 콘텐츠로 건너뛰기
Epson Stylus Photo 1400 Ink cartridge replacement
필요한 것
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 1 단계, 이미지 1/2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 1 단계, 이미지 2/2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: 2 단계, 이미지 1/2 Epson Stylus Photo 1400 Ink cartridge replacement: 2 단계, 이미지 2/2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: 3 단계, 이미지 1/2 Epson Stylus Photo 1400 Ink cartridge replacement: 3 단계, 이미지 2/2
    • Close cartridge cover.
    • Close cover of the printer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Larry Huang
회원 가입일: 10/12/11
1,004 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 회원
CPSU-REGAN-F11S17G11
4 회원들
안내서 12개 작성하였습니다
댓글 5개
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - 답글
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - 답글
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - 답글
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - 답글
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 21
전체 시간: 10,070
