소개
This guide shows how to remove the paper eject frame assembly Constant paper jams might be caused by a faulty paper eject frame assembly. This process requires the knowledge of how to use basic tools.
필요한 것
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Start by emptying the ink tube.
Hold the left side of the ink tube in your hand.
Pull the sides of the tube apart and empty the waste.
다른 41명이 해당 안내서를 완성하였습니다.
