주요 콘텐츠로 건너뛰기
Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement
필요한 것
  1. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Housing: 1 단계, 이미지 1/1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 2 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 2 단계, 이미지 2/2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 3 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 4 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 5 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 5 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 5 단계, 이미지 3/3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 6 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 6 단계, 이미지 2/2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 7 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 7 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 7 단계, 이미지 3/3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 8 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 8 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 8 단계, 이미지 3/3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 9 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 9 단계, 이미지 2/2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 10 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 10 단계, 이미지 2/2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 11 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 11 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 11 단계, 이미지 3/3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 12 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 12 단계, 이미지 2/2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
  13. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: 13 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: 13 단계, 이미지 2/2
    • Start by emptying the ink tube.
    • Hold the left side of the ink tube in your hand.
    • Pull the sides of the tube apart and empty the waste.
  14. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 14 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 14 단계, 이미지 2/2
    • Remove the acetate tape that secures the connector cable.
  15. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 15 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 15 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 15 단계, 이미지 3/3
    • There are six screws that secure the printer mechanism.
    • Remove the first three 10 mm screws that hold the printer mechanism in place using a Phillips #2 screwdriver.
  16. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 16 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 16 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 16 단계, 이미지 3/3
    • Remove the other three 10 mm screws that secure the printer mechanism using a Phillips #2 screwdriver.
  17. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 17 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 17 단계, 이미지 2/2
    • The printer mechanism is located on the lower housing.
    • Remove the mechanism by holding the handles and lifting upwards.
  18. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 18 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 18 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 18 단계, 이미지 3/3
    • Remove the CD-R unit housing. Release the two attaching points to the tray base and then pull out the unit diagonally one side at a time.
  19. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 19 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 19 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 19 단계, 이미지 3/3
    • Detach the left frame support plate. Start by removing the two 6 mm screws that secure it and then pull it out by hand.
  20. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 20 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 20 단계, 이미지 2/2
    • Remove the four 6 mm screws using the Phillips #2 screwdriver.
    • Remove the two 8 mm screw using a Phillips #2 screwdriver.
    • The screws are located on the lower sections of the printer.
  21. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 21 단계, 이미지 1/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 21 단계, 이미지 2/3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 21 단계, 이미지 3/3
    • Two guide pins secure the paper eject assembly in place.
    • Pull out the two guide pins on the CD/DVD tray base.
  22. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 22 단계, 이미지 1/2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 22 단계, 이미지 2/2
    • Remove the paper eject frame assembly by pulling it towards you.
결론
다른 41명이 해당 안내서를 완성하였습니다.
Larry Huang
회원 가입일: 10/12/11
1,004 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 회원
CPSU-REGAN-F11S17G11
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 55
전체 시간: 21,047
