주요 콘텐츠로 건너뛰기
Epson Stylus Photo 820 Ink Cartridges Replacement
  1. Epson Stylus Photo 820 Ink Cartridges Replacement, Ink Cartridges: 1 단계, 이미지 1/1
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Epson Stylus Photo 820 Ink Cartridges Replacement: 2 단계, 이미지 1/2 Epson Stylus Photo 820 Ink Cartridges Replacement: 2 단계, 이미지 2/2
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Epson Stylus Photo 820 Ink Cartridges Replacement: 3 단계, 이미지 1/2 Epson Stylus Photo 820 Ink Cartridges Replacement: 3 단계, 이미지 2/2
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Epson Stylus Photo 820 Ink Cartridges Replacement: 4 단계, 이미지 1/3 Epson Stylus Photo 820 Ink Cartridges Replacement: 4 단계, 이미지 2/3 Epson Stylus Photo 820 Ink Cartridges Replacement: 4 단계, 이미지 3/3
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Epson Stylus Photo 820 Ink Cartridges Replacement: 5 단계, 이미지 1/3 Epson Stylus Photo 820 Ink Cartridges Replacement: 5 단계, 이미지 2/3 Epson Stylus Photo 820 Ink Cartridges Replacement: 5 단계, 이미지 3/3
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Lin
회원 가입일: 04/10/11
99 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G68
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 2,924
