주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Epson WF-3640 Firmware Upgrade
필요한 것
  1. Epson WF-3640 Firmware Upgrade, Make sure your printer is powered up and network connected.: 1 단계, 이미지 1/1
    • You won't be able to proceed effectively if the printer can't be pinged on the network!
    • Note: you may be able to apply these principles to many other printers whose firmwares support a web user interface. The menus will vary of course.
  2. Epson WF-3640 Firmware Upgrade: 2 단계, 이미지 1/1
    • Open a browser window on any device attached to your network and type in the local network address of the printer.
  3. Epson WF-3640 Firmware Upgrade: 3 단계, 이미지 1/1
    • Scroll to bottom of left panel with scroll thumb. Click on "Basic Settings" link there.
  4. Epson WF-3640 Firmware Upgrade: 4 단계, 이미지 1/1
    • Click on "Firmware Update" link.
  5. Epson WF-3640 Firmware Upgrade: 5 단계, 이미지 1/1
    • Read and understand instructions before proceeding.
  6. Epson WF-3640 Firmware Upgrade: 6 단계, 이미지 1/1
    • Scroll to bottom of page to expose the "Start/Back to Main" buttons. Press "Start" if you are ready to attempt the firmware upgrade. Otherwise you can just close the browser tab/window if you have changed your plans.
  7. Epson WF-3640 Firmware Upgrade: 7 단계, 이미지 1/1
    • After a few moments you will see this screen as it tests to see if your printer firmware is up to date.
  8. Epson WF-3640 Firmware Upgrade: 8 단계, 이미지 1/1
    • If your system is already up to date you will see this page. Otherwise a page with your final confirmation options will be displayed, or you can close the browser session if you decide against upgrading of course. The warnings about not interrupting the upgrade will be given also. It will caution you against powering off while upgrade proceeds.
  9. Epson WF-3640 Firmware Upgrade: 9 단계, 이미지 1/1
    • When upgrade is completed your web interface will advise you that the printer is ready to be restarted or maybe it takes care of the hardware restart for you... I don't remember but it is pretty foolproof if you just follow the screen instructions the web interface provides. I have used this to revive completely dead (non-printing) printers too!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
tcagle53
회원 가입일: 06/18/14
8,234 평판
안내서 10개 작성하였습니다
Chromebook Cowboys Chromebook Cowboys 회원
Community
2 회원들
안내서 25개 작성하였습니다
댓글 2개
Glad it helped you. Unfortunately as time has gone on ink jet printers have evolved and many now leverage these updating facilities to add “features” to printers that are not really in the consumer’s interest. I am thinking primarily of locking you into using exclusive OEM ink cartridges and the so-called waste boxes and so forth. If the manufacturers would put as much effort into building robust paper handling mechanisms as they do to trying to lock you into their supplies they might realize some actual brand loyalty love. Rant mode off.
tcagle53 -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 2,381
