주요 콘텐츠로 건너뛰기
Equestic SaddleClip USB Micro-B Connector and Battery Replacement
필요한 것
  1. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Introduction: 1 단계, 이미지 1/2 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Introduction: 1 단계, 이미지 2/2
    • The T8 screws visible inside the clip jaws are not accessible at this stage.
  2. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing Hinge: 2 단계, 이미지 1/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing Hinge: 2 단계, 이미지 2/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing Hinge: 2 단계, 이미지 3/3
    • The hinge pin needs to be pressed out to remove the clip
    • The overmoulded rubber hides one side of the pin as shown in the picture.
    • Align a sharp pointed driver or pin over where the end of the pin is hidden.
    • Gently tap the driver or pin with a hammer until the opposite end protrudes far enough to grip with pliers
    • Grip the protruding pin with pliers and pull it out
  3. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Begin front panel removal: 3 단계, 이미지 1/1
    • Using T8 driver remove the two screws on the back of case.
    • The hinge block and front panel (with the 'eq' logo) should now feel loose - but is not removeable yet.
  4. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Finish front panel removal: 4 단계, 이미지 1/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Finish front panel removal: 4 단계, 이미지 2/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Finish front panel removal: 4 단계, 이미지 3/3
    • There are two hidden clips approximately circled in yellow.
    • Two options for removing panel
    • If you have two thin pins you can try inserting them where the orange arrows are in the first image, through the orange slots in the second image.
    • Or you can gently pull the panel on an angle in the direction of the indicator LED until the clips disengage.
    • The clips and retainers are shown in the second and third images.
  5. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing back panel: 5 단계, 이미지 1/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing back panel: 5 단계, 이미지 2/3 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Removing back panel: 5 단계, 이미지 3/3
    • The hinge block highlighted in green (with the screws removed in step 3) feels loose, but is still retained with 2 clips
    • If you look down inside the open front, you can just make out two triangular clips located in the yellow circles. These clips hold the hinge block to the PCB.
    • Using some sharp tweezers gently release the pcb clips and the hinge block will release.
  6. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Remove PCB: 6 단계, 이미지 1/2 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Remove PCB: 6 단계, 이미지 2/2
    • Using the T5 driver remove the three screws (one under front panel, and two under hinge block).
    • The PCB will now release easily.
  7. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Inspection of PCB: 7 단계, 이미지 1/2 Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Inspection of PCB: 7 단계, 이미지 2/2
    • The Li-Ion battery holder is visible on one side, along with the USB Micro-B connector that in this case has been damaged.
    • USB Connector is a Wurth Electronics part #629105136821
    • Battery is a LIR2450 3.6V 120mAh rechargeable Lithium-Ion button cell.
    • The other side of the PCB shows the main components including:
    • CC2640: Texas instruments wireless MCU with Bluetooth
    • MX25L3233FM2I-08G: Macronix 32Mbit Serial Flash
    • MPU-6500: InvenSense 6-Axis motion tracker (3-Axis Gyroscope and 3-Axis Accelerometer)
  8. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Repair and Replace: 8 단계, 이미지 1/1
    • Repair and replace as required for your circumstances.
    • In this case the USB connector is replaced and reinforced as the locating pads have pulled off the PCB.
    • Note that only pins 1 and 5 are used (VBus and GND). No data connection is present.
  9. Equestic SaddleClip USB Micro-B Connector and Battery Replacement, Reassembly: 9 단계, 이미지 1/1
    • Follow these instructions in reverse order to reassemble the Equestic SaddleClip
    • Note that the battery must be installed before the PCB screws.
결론
Ben Moores
회원 가입일: 05/24/19
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 635
