주요 콘텐츠로 건너뛰기
Equity Alarm Clock 13014 Alarm Replacement
필요한 것
  1. Equity Alarm Clock 13014 Alarm Replacement, Alarm: 1 단계, 이미지 1/3 Equity Alarm Clock 13014 Alarm Replacement, Alarm: 1 단계, 이미지 2/3 Equity Alarm Clock 13014 Alarm Replacement, Alarm: 1 단계, 이미지 3/3
    • Use a spudger to open and detach the wiring box from the clock. Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock. Be careful while handling the box and clock to avoid any damage or injury.
  2. Equity Alarm Clock 13014 Alarm Replacement: 2 단계, 이미지 1/1
    • To remove the box, please use your fingers to gently grasp it and lift it out. Be careful not to apply too much pressure or force that could damage the box .
  3. Equity Alarm Clock 13014 Alarm Replacement: 3 단계, 이미지 1/2 Equity Alarm Clock 13014 Alarm Replacement: 3 단계, 이미지 2/2
    • Use a soldering iron to melt the solder on each wire connection to safely remove the wires.
  4. Equity Alarm Clock 13014 Alarm Replacement: 4 단계, 이미지 1/2 Equity Alarm Clock 13014 Alarm Replacement: 4 단계, 이미지 2/2
    • To replace the wiring box, use your hand to remove the old one and install a new one in its place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alaa
회원 가입일: 10/27/14
311 평판
안내서 2개 작성하였습니다
댓글 한 개
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 44
전체 시간: 3,136
