이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a spudger to open and detach the wiring box from the clock. Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock. Be careful while handling the box and clock to avoid any damage or injury.
To remove the box, please use your fingers to gently grasp it and lift it out. Be careful not to apply too much pressure or force that could damage the box .
Use a soldering iron to melt the solder on each wire connection to safely remove the wires.
To replace the wiring box, use your hand to remove the old one and install a new one in its place.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
