주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Equity Alarm Clock 13014 Clock Hands Replacement
필요한 것
    1. Equity Alarm Clock 13014 Clock Hands Replacement, Screws and Back Plate: 1 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Screws and Back Plate: 1 단계, 이미지 2개 중 2개
      • Using a Phillips screwdriver, remove the top screw.
      • Repeat for other two screws located on the lower right and left sides of the clock.
      댓글 쓰기
    2. Equity Alarm Clock 13014 Clock Hands Replacement, Back Plate and Clock's Inner Apparatus: 2 단계, 이미지 1개 중 1개
      • Place fingers on ridge around back plate and pull upward.
      댓글 쓰기
    3. Equity Alarm Clock 13014 Clock Hands Replacement, Silver Base and Cellinoid: 3 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Silver Base and Cellinoid: 3 단계, 이미지 2개 중 2개
      • Using a Phillips screwdriver, remove the silver base located on top of cellinoid in upper right hand of inner clock.
      댓글 쓰기
    4. Equity Alarm Clock 13014 Clock Hands Replacement, The Bell: 4 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, The Bell: 4 단계, 이미지 2개 중 2개
      • Using a Phillips Screwdriver, remove bell from inner clock.
      댓글 쓰기
    5. Equity Alarm Clock 13014 Clock Hands Replacement, Cellinoid From Clock: 5 단계, 이미지 1개 중 1개
      • Cellinoid is located below Silver Base. Remove Cellinoid with your fingers and pull it up from the inner clock apparatus.
      댓글 쓰기
    6. Equity Alarm Clock 13014 Clock Hands Replacement, Bottom Legs: 6 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Bottom Legs: 6 단계, 이미지 2개 중 2개
      • Remove the bottom legs of the clock by unscrewing them with your fingers.
      • Caution: you may need to use a pair of pliers if bottom legs are attached too tight.
      댓글 쓰기
    7. Equity Alarm Clock 13014 Clock Hands Replacement, Right Bell Screw: 7 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Right Bell Screw: 7 단계, 이미지 2개 중 2개
      • Using your hands, unscrew top screw located on top of the right bell.
      • Caution: You may need to use a pair of pliers to loosen the screw.
      댓글 쓰기
    8. Equity Alarm Clock 13014 Clock Hands Replacement, Left Bell Screw: 8 단계, 이미지 3개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Left Bell Screw: 8 단계, 이미지 3개 중 2개 Equity Alarm Clock 13014 Clock Hands Replacement, Left Bell Screw: 8 단계, 이미지 3개 중 3개
      • Repeat Directions in Step 6 but on the left bell screw.
      • Caution: You may need to use a pair of pliers.
      댓글 쓰기
    9. Equity Alarm Clock 13014 Clock Hands Replacement, Bells and Connecting Bar: 9 단계, 이미지 3개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Bells and Connecting Bar: 9 단계, 이미지 3개 중 2개 Equity Alarm Clock 13014 Clock Hands Replacement, Bells and Connecting Bar: 9 단계, 이미지 3개 중 3개
      • After you remove the screws for both bells, both of the two bells and the bar connecting the two bells will easily come off. Remove these three components with your fingers.
      댓글 쓰기
    10. Equity Alarm Clock 13014 Clock Hands Replacement, Remainder of Inner Clock Apparatus: 10 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Remainder of Inner Clock Apparatus: 10 단계, 이미지 2개 중 2개
      • Using your hand, remove the entire black, inner apparatus of clock. The golden ridge of the clock is attached to the glass screen.
      댓글 쓰기
    11. Equity Alarm Clock 13014 Clock Hands Replacement, Inner Clock Apparatus Around and Clock Numbers: 11 단계, 이미지 2개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Inner Clock Apparatus Around and Clock Numbers: 11 단계, 이미지 2개 중 2개
      • In the front of the clock apparatus are the twelve numbers, minute hand, second hand, and hour hand.
      댓글 쓰기
    12. Equity Alarm Clock 13014 Clock Hands Replacement, Clock Hands: 12 단계, 이미지 3개 중 1개 Equity Alarm Clock 13014 Clock Hands Replacement, Clock Hands: 12 단계, 이미지 3개 중 2개 Equity Alarm Clock 13014 Clock Hands Replacement, Clock Hands: 12 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using a pair of tweezers, remove the golden peg in the center of the clock. This attaches the minute, hour and second hands.
      • After you have removed the golden peg, use the pair of tweezers to remove hour, minute and second hands.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Michael Johnson
회원 가입일: 11/03/14
327 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 63
전체 시간: 3,538
