주요 콘텐츠로 건너뛰기
Escort Passport 9500IX Button Board Replacement
필요한 것
  1. Escort Passport 9500IX Button Board Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
  2. Escort Passport 9500IX Button Board Replacement: 2 단계, 이미지 1/1
    • Pry off the back panel of the radar using the nylon spudger.
  3. Escort Passport 9500IX Button Board Replacement, Buttons: 3 단계, 이미지 1/3 Escort Passport 9500IX Button Board Replacement, Buttons: 3 단계, 이미지 2/3 Escort Passport 9500IX Button Board Replacement, Buttons: 3 단계, 이미지 3/3
    • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
  4. Escort Passport 9500IX Button Board Replacement: 4 단계, 이미지 1/2 Escort Passport 9500IX Button Board Replacement: 4 단계, 이미지 2/2
    • Slowly peel the buttons off the button board.
  5. Escort Passport 9500IX Button Board Replacement, Button Board: 5 단계, 이미지 1/3 Escort Passport 9500IX Button Board Replacement, Button Board: 5 단계, 이미지 2/3 Escort Passport 9500IX Button Board Replacement, Button Board: 5 단계, 이미지 3/3
    • Detach the orange flap on the motherboard.
    • Carefully remove the motherboard from the grey plastic frame.
  6. Escort Passport 9500IX Button Board Replacement: 6 단계, 이미지 1/1
    • Detach the orange flap directly behind the button board.
  7. Escort Passport 9500IX Button Board Replacement: 7 단계, 이미지 1/3 Escort Passport 9500IX Button Board Replacement: 7 단계, 이미지 2/3 Escort Passport 9500IX Button Board Replacement: 7 단계, 이미지 3/3
    • Carefully pull out the button board from the grey frame.
결론
Kennedy Morales
회원 가입일: 10/20/17
655 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G3, Peak Fall 2018 UMass Dartmouth, Team S2-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 546
