주요 콘텐츠로 건너뛰기
Escort Passport 9500IX Display Replacement
필요한 것
  1. Escort Passport 9500IX Display Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
  2. Escort Passport 9500IX Display Replacement: 2 단계, 이미지 1/1
    • Pry off the back panel of the radar using the nylon spudger.
  3. Escort Passport 9500IX Display Replacement, Display: 3 단계, 이미지 1/3 Escort Passport 9500IX Display Replacement, Display: 3 단계, 이미지 2/3 Escort Passport 9500IX Display Replacement, Display: 3 단계, 이미지 3/3
    • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
  4. Escort Passport 9500IX Display Replacement: 4 단계, 이미지 1/3 Escort Passport 9500IX Display Replacement: 4 단계, 이미지 2/3 Escort Passport 9500IX Display Replacement: 4 단계, 이미지 3/3
    • Detach the orange flap from the motherboard using a nylon spudger.
    • Carefully remove the motherboard from the grey plastic frame.
  5. Escort Passport 9500IX Display Replacement: 5 단계, 이미지 1/2 Escort Passport 9500IX Display Replacement: 5 단계, 이미지 2/2
    • Detach the remaining two orange flaps from the circuit board that is attached onto the grey frame.
  6. Escort Passport 9500IX Display Replacement: 6 단계, 이미지 1/2 Escort Passport 9500IX Display Replacement: 6 단계, 이미지 2/2
    • Detach the display from the grey frame.
결론
Jiahao Xu
회원 가입일: 10/25/18
177 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G3, Peak Fall 2018 UMass Dartmouth, Team S2-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 28
전체 시간: 1,838
