주요 콘텐츠로 건너뛰기
Escort Passport Max2 Display Replacement
필요한 것
  1. Escort Passport Max2 Display Replacement, Exterior Case: 1 단계, 이미지 2개 중 1개 Escort Passport Max2 Display Replacement, Exterior Case: 1 단계, 이미지 2개 중 2개
    • Inser the flat end of a spudger into one of the two notches and pry off the case.
  2. Escort Passport Max2 Display Replacement: 2 단계, 이미지 2개 중 1개 Escort Passport Max2 Display Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the spudger around the perimeter of the radar housing until the case separates.
  3. Escort Passport Max2 Display Replacement: 3 단계, 이미지 2개 중 1개 Escort Passport Max2 Display Replacement: 3 단계, 이미지 2개 중 2개
    • Repeat these steps to remove the other side.
  4. Escort Passport Max2 Display Replacement, Lens: 4 단계, 이미지 2개 중 1개 Escort Passport Max2 Display Replacement, Lens: 4 단계, 이미지 2개 중 2개
    • Remove the four 9mm Phillips #1 screws from the bottom of the radar.
    • Remove the bottom case.
  5. Escort Passport Max2 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
    • The silver frame can easily pop off of the device now that the bottom metal case has been removed. Don't worry if it comes off all the way. It can easily be put back in it's place.
  6. Escort Passport Max2 Display Replacement, Display: 6 단계, 이미지 2개 중 1개 Escort Passport Max2 Display Replacement, Display: 6 단계, 이미지 2개 중 2개
    • Push the two black tabs down to release the ribbon attached to the display.
    • The display ribbon should now easily slip out from under the white strip.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kelsey Ferrenberg
회원 가입일: 04/12/18
770 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G1, Liner Spring 2018 UW Tacoma, Team S1-G1, Liner Spring 2018 회원
UWT-LINER-S18S1G1
5 회원들
안내서 4개를 작성함
12가이드 댓글
Kelsey, Where do you get the part? I need a replacement screen for my Passport Max FB30947A3. Escort customer service won’t sell it to me and requires me to send the unit to them for a bog fee.
Doug Denny - 답글
I also need to replace my screen and would like to know where I can get the part. Mine was dropped and the screen cracked. I do not feel like spending $139 to repair an older detector. Thanks for any info you can provide!
Aaron k - 답글
I need a display screen for a max 2
Jeff Dowdy - 답글
Where can a replacement screen be ordered?
Mike Rumble - 답글
Escort Max II screens are now available in ebay
John -
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 28
지난 30일: 140
전체 시간: 4,367
