주요 콘텐츠로 건너뛰기
Etón Scorpion Battery Replacement
필요한 것
  1. Etón Scorpion Battery Replacement, Battery: 1 단계, 이미지 1/3 Etón Scorpion Battery Replacement, Battery: 1 단계, 이미지 2/3 Etón Scorpion Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Your device should look like this.
  2. Etón Scorpion Battery Replacement: 2 단계, 이미지 1/1
    • Turn the unit on its side and look for this panel.
  3. Etón Scorpion Battery Replacement: 3 단계, 이미지 1/3 Etón Scorpion Battery Replacement: 3 단계, 이미지 2/3 Etón Scorpion Battery Replacement: 3 단계, 이미지 3/3
    • Unscrew this screw with a Phillips head #0 screwdriver.
    • Remove the panel.
  4. Etón Scorpion Battery Replacement: 4 단계, 이미지 1/3 Etón Scorpion Battery Replacement: 4 단계, 이미지 2/3 Etón Scorpion Battery Replacement: 4 단계, 이미지 3/3
    • Pull out the battery and disconnect the connector.
결론
To reassemble your device, follow these instructions in reverse order, and remember to connect the connector when putting in a new battery.
다른 한 분이 해당 안내서를 완성하였습니다.
9021007
회원 가입일: 07/13/18
4,599 평판
안내서 25개 작성하였습니다
댓글 3개
What specific battery did you purchase to replace the original battery pack? My battery needs to be 1.25” by 1.25” to fit into the compartment. Many of the batteries I have found on Amazon that claim to be replacement are much larger an won’t fit into the compartment.
Mark Chapin - 답글
https://www.amazon.com/South-33053-Cordl...
This battery seems to be a good fit. It says in the question and answer section that it’s 1.2"" x 1.15"x 0.42".
9021007 -
Need to switch the wire positions. What's the best way?
David - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 1,087
