주요 콘텐츠로 건너뛰기
Etekcity Lasergrip 1080 Motherboard Replacement
필요한 것
  1. Etekcity Lasergrip 1080 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Motherboard Replacement: 2 단계, 이미지 1/1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Motherboard Replacement: 3 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement: 3 단계, 이미지 2/2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: 4 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: 4 단계, 이미지 2/2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Motherboard Replacement: 5 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Motherboard Replacement: 7 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement: 7 단계, 이미지 2/2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Motherboard Replacement: 8 단계, 이미지 1/1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2/2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Motherboard Replacement, Laser: 10 단계, 이미지 1/1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Motherboard Replacement: 11 단계, 이미지 1/1
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
  12. Etekcity Lasergrip 1080 Motherboard Replacement, Sensor: 12 단계, 이미지 1/1
  13. Etekcity Lasergrip 1080 Motherboard Replacement: 13 단계, 이미지 1/1
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
  14. Etekcity Lasergrip 1080 Motherboard Replacement, Battery Connector: 14 단계, 이미지 1/1
  15. Etekcity Lasergrip 1080 Motherboard Replacement: 15 단계, 이미지 1/1
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
  16. Etekcity Lasergrip 1080 Motherboard Replacement, Screen: 16 단계, 이미지 1/1
    • Carefully pull the motherboard out of its slot in the body of the device.
  17. Etekcity Lasergrip 1080 Motherboard Replacement: 17 단계, 이미지 1/2 Etekcity Lasergrip 1080 Motherboard Replacement: 17 단계, 이미지 2/2
    • Unscrew the two 3.4 mm screws on the motherboard.
  18. Etekcity Lasergrip 1080 Motherboard Replacement: 18 단계, 이미지 1/1
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
결론
Patrick Crawford
회원 가입일: 08/26/15
741 평판
안내서 6개 작성하였습니다
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 470
