주요 콘텐츠로 건너뛰기
Etekcity Lasergrip 1080 Trigger Replacement
필요한 것
  1. Etekcity Lasergrip 1080 Trigger Replacement, Battery: 1 단계, 이미지 1/1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Trigger Replacement: 2 단계, 이미지 1/1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Trigger Replacement: 3 단계, 이미지 1/2 Etekcity Lasergrip 1080 Trigger Replacement: 3 단계, 이미지 2/2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Trigger Replacement, Buttons: 4 단계, 이미지 1/2 Etekcity Lasergrip 1080 Trigger Replacement, Buttons: 4 단계, 이미지 2/2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Trigger Replacement: 5 단계, 이미지 1/2 Etekcity Lasergrip 1080 Trigger Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Trigger Replacement: 6 단계, 이미지 1/1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Trigger Replacement: 7 단계, 이미지 1/2 Etekcity Lasergrip 1080 Trigger Replacement: 7 단계, 이미지 2/2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Trigger Replacement: 8 단계, 이미지 1/1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Trigger Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 1/2 Etekcity Lasergrip 1080 Trigger Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2/2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
결론
Patrick Crawford
회원 가입일: 08/26/15
741 평판
안내서 6개 작성하였습니다
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 611
