주요 콘텐츠로 건너뛰기
Ethernet Port Replacement
필요한 것
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 1개 Ethernet Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 2개 Ethernet Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: 3 단계, 이미지 1개 중 1개
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: 4 단계, 이미지 3개 중 1개 Ethernet Port Replacement: 4 단계, 이미지 3개 중 2개 Ethernet Port Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: 5 단계, 이미지 3개 중 1개 Ethernet Port Replacement, Ethernet Ports: 5 단계, 이미지 3개 중 2개 Ethernet Port Replacement, Ethernet Ports: 5 단계, 이미지 3개 중 3개
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: 6 단계, 이미지 1개 중 1개
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Denis
회원 가입일: 09/15/16
611 평판
안내서 3개를 작성함
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 51
전체 시간: 8,247
