주요 콘텐츠로 건너뛰기
Eton FRX3 Case Assembly Disassembly
필요한 것
  1. Eton FRX3 Case Assembly Disassembly, Rechargeable Battery Pack: 1 단계, 이미지 1/1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Case Assembly Disassembly: 2 단계, 이미지 1/1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Case Assembly Disassembly, Case Assembly: 3 단계, 이미지 1/1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Case Assembly Disassembly: 4 단계, 이미지 1/1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Case Assembly Disassembly: 5 단계, 이미지 1/1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Case Assembly Disassembly: 6 단계, 이미지 1/1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Case Assembly Disassembly: 7 단계, 이미지 1/1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
결론
To reassemble your device, follow these instructions in the reverse order.
james
회원 가입일: 11/29/13
2,213 평판
안내서 2개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,526개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 400
