주요 콘텐츠로 건너뛰기
소개
While unlikely, your FM antenna may become damaged at some point. If it is, you'll either hear background noise or suffer a loss of signal entirely. In such a case you may need to replace the antenna to bring it to working order.
  1. Eton FRX3 FM Radio Antenna Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1/1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 FM Radio Antenna Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 FM Radio Antenna Replacement, Case Assembly: 3 단계, 이미지 1/1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 FM Radio Antenna Replacement: 4 단계, 이미지 1/1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 FM Radio Antenna Replacement: 5 단계, 이미지 1/1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 FM Radio Antenna Replacement: 6 단계, 이미지 1/1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 FM Radio Antenna Replacement: 7 단계, 이미지 1/1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 FM Radio Antenna Replacement, FM Radio Antenna: 8 단계, 이미지 1/1
    • Remove the Philips #1 screw, securing the FM radio antenna to the case.
  9. Eton FRX3 FM Radio Antenna Replacement: 9 단계, 이미지 1/1
    • From the back of the device, gently pull the antenna out of the device case.
결론
To reassemble your device, follow these instructions in the reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Md Siamul Islam
회원 가입일: 2016년 02월 10일
420 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 13개 작성하였습니다
댓글 3개
I bought 2 of these overpriced made in China crap and antenna broke off easily on both. Truly disappointed . Want to replace them with better heavy duty antenna. What brand and model and company do you recommend U buy the antennas from?
Olga Limkin - 답글
where can I get the antenna?
Claude Raasch - 답글
This helps when you leave it within reach of a 5 yr old who swears he did it when "he was little"
Joseph - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 1,678
