주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eton FRX3 Motherboard Assembly Replacement
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
    1. Eton FRX3 Motherboard Assembly Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1개 중 1개
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      댓글 쓰기
    2. Eton FRX3 Motherboard Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Disconnect the battery pack wires from the device and remove the battery pack.
      댓글 쓰기
    1. Eton FRX3 Motherboard Assembly Replacement, Case Assembly: 3 단계, 이미지 1개 중 1개
      • Use the T10 hexagonal tip from the iFixit Bit Driver Kit or comparable tool to remove the two 22 mm hexagonal screws on the front face of the device.
      댓글 쓰기
    2. Eton FRX3 Motherboard Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the two 22 mm hexagonal screws on the upper rear of the device.
      댓글 쓰기
    3. Eton FRX3 Motherboard Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Use a long, slender screwdriver to reach and remove the two 10 mm Phillips #00 screws recessed deep in the body of the device.
      • If you're using the 54-bit toolkit, the female hexagonal bit can be used to extend the reach of the Phillips #00 bit.
      댓글 쓰기
    4. Eton FRX3 Motherboard Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • On the bottom of the device are two rubber feet. Using the blue plastic opening tool, pry them up and pull straight off.
      • It’s best to place these on their non-sticky side while you work, as you’ll want them to keep as much tackiness as possible for reassembly.
      댓글 쓰기
    5. Eton FRX3 Motherboard Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Pull apart the two halves of the device at the seam.
      • Three components from the back half will prevent you from fully opening the device, just unplug these connections as shown in the image.
      댓글 쓰기
    1. Eton FRX3 Motherboard Assembly Replacement, Tuning Dial: 8 단계, 이미지 1개 중 1개
      • Unplug the socket connection from the motherboard as shown in the image.
      댓글 쓰기
    2. Eton FRX3 Motherboard Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
      댓글 쓰기
    3. Eton FRX3 Motherboard Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • Gently lift the dial upwards to remove it.
      댓글 쓰기
    1. Eton FRX3 Motherboard Assembly Replacement, Motherboard Assembly: 11 단계, 이미지 1개 중 1개
      • Unplug all the component socket connections from the motherboard as shown in the image.
      댓글 쓰기
    2. Eton FRX3 Motherboard Assembly Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the six 1 cm Phillips #0 screws that secure the motherboard to the case.
      댓글 쓰기
    3. Eton FRX3 Motherboard Assembly Replacement: 13 단계, 이미지 1개 중 1개
      • Fold the motherboard over the bottom of the device case.
      • Be careful not to damage the wires leading to the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Azhar Albusaidi
회원 가입일: 02/10/16
143 평판
안내서 1개를 작성함
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 93개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 20
전체 시간: 415
