주요 콘텐츠로 건너뛰기
Eton FRX3 Radio Mode Switch Replacement
필요한 것
  1. Eton FRX3 Radio Mode Switch Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1/1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Radio Mode Switch Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Radio Mode Switch Replacement, Case Assembly: 3 단계, 이미지 1/1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Radio Mode Switch Replacement: 4 단계, 이미지 1/1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Radio Mode Switch Replacement: 5 단계, 이미지 1/1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Radio Mode Switch Replacement: 6 단계, 이미지 1/1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Radio Mode Switch Replacement: 7 단계, 이미지 1/1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 Radio Mode Switch Replacement, Tuning Dial: 8 단계, 이미지 1/1
    • Unplug the socket connection from the motherboard as shown in the image.
  9. Eton FRX3 Radio Mode Switch Replacement: 9 단계, 이미지 1/1
    • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
  10. Eton FRX3 Radio Mode Switch Replacement: 10 단계, 이미지 1/1
    • Gently lift the dial upwards to remove it.
  11. Eton FRX3 Radio Mode Switch Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
  12. Eton FRX3 Radio Mode Switch Replacement: 12 단계, 이미지 1/1
    • Unplug all the component socket connections from the motherboard.
  13. Eton FRX3 Radio Mode Switch Replacement: 13 단계, 이미지 1/1
    • Desolder the two wires that connect the speaker to the motherboard.
  14. Eton FRX3 Radio Mode Switch Replacement: 14 단계, 이미지 1/1
    • Gently lift the motherboard upwards to remove it from the device.
  15. Eton FRX3 Radio Mode Switch Replacement, Radio Mode Switch: 15 단계, 이미지 1/1
    • On the back of the motherboard, just below the LCD screen, gently pull up on the small, black plastic switch to remove it.
결론
Kenneth Sills
회원 가입일: 02/10/16
762 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 261
