주요 콘텐츠로 건너뛰기
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1/1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: 2 단계, 이미지 1/1
    • Disconnect the battery pack wires from the device and remove the battery pack.
결론
To reassemble your device, follow these instructions in the reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Kenneth Sills
회원 가입일: 02/10/16
762 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 13개 작성하였습니다
댓글 4개
My question is where can you find an FRX3 replacement battery?
jalwitt - 답글
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - 답글
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 45
전체 시간: 5,318
