주요 콘텐츠로 건너뛰기
Eufy RoboVac 11S Filters Replacement
필요한 것
  1. Eufy RoboVac 11S Filters Replacement, Filters: 1 단계, 이미지 1/2 Eufy RoboVac 11S Filters Replacement, Filters: 1 단계, 이미지 2/2
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: 2 단계, 이미지 1/2 Eufy RoboVac 11S Filters Replacement: 2 단계, 이미지 2/2
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: 3 단계, 이미지 1/3 Eufy RoboVac 11S Filters Replacement: 3 단계, 이미지 2/3 Eufy RoboVac 11S Filters Replacement: 3 단계, 이미지 3/3
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: 4 단계, 이미지 1/3 Eufy RoboVac 11S Filters Replacement: 4 단계, 이미지 2/3 Eufy RoboVac 11S Filters Replacement: 4 단계, 이미지 3/3
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: 5 단계, 이미지 1/1
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: 6 단계, 이미지 1/2 Eufy RoboVac 11S Filters Replacement: 6 단계, 이미지 2/2
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: 7 단계, 이미지 1/2 Eufy RoboVac 11S Filters Replacement: 7 단계, 이미지 2/2
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
결론
다른 2명이 해당 안내서를 완성하였습니다.
felix
회원 가입일: 05/13/20
181 평판
안내서 1개 작성함
York University, Team S1-G27, O'Regan Summer 2020 York University, Team S1-G27, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G27
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 86
전체 시간: 4,819
